Thermaltake Level 20 kuciste
Discussion in 'Storage, kućišta, napajanja i hlađenje' started by lolak, Jan 9, 2018.
  1. lolak
    lolak Aktivista
    The Level 20 is the next generation of the legendary Level 10 Extreme Gaming Chassis, which was released around a decade ago. Within these 10 years, Thermaltake achieved several breakthroughs in terms of design and technology. Featuring a gaming oriented design with architectural aesthetics, the aluminum-made Level 20, utilizes an aerodynamic trio chamber structure to achieve ventilation and space management optimization.
    The Three hinged swing-doors are made with premium-quality 4mm thick tempered glass windows that provide durability and superb viewing capability. The Level 20 is installed with latest USB 3.1 Type-C port to provide 10G of transmission speed. Furthermore the Level 20 has three built in Riing Plus 14 RGB Fans and two Lumi Plus LED Strips. This can all be controlled with the included Riing Plus RGB Controller and Riing Plus RGB Software, allowing users to custom control fan speeds and lighting effects.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Neo Bahamut Zero
    Kakva gomila RGB seljačenja. :D
  3. lolak
    lolak Aktivista
    Sto, jeste bling, ali lijepo izgleda :)
    Haker Overclocker
    Grozno. K'o svijetljeće kutije od cipela naslagane jedna na drugu.
  5. Neo Bahamut Zero
    Meni je užas, doduše ja sam veliki protivnik ovog RGB trenda; isključio sam svaku led diodu u kompu osim hdd indikatora. :D
    Haker Overclocker
    Pa ne znam kako se odrastao čovjek može furati na lingišpir u kompu :D
  7. dmr
    isto ko sto se moze furati na video igre :D
  8. Neo Bahamut Zero
    Ove pizdarije ti samo mogu smetati i skretati pažnju sa ekrana ukoliko kućište stoji na stolu (a u ovim slučajevima je to obavezno da bi bling-bling efekat došao do izražaja). :D
  9. Piroman
    Piroman Komšija
    Ja da mogu, ukinuo bih ove led lampice na modemu jer mi i one previše "šljašte" i živciraju! A Power i HDD LED na kučištu sam davno "pokrio" malom mikrofaser krpom! :D
  10. EL NINO CFC
    Meni je ok u odredjenoj mjeri, i jos kad ima zatamnjeno staklo sa strane
  11. hamo pipa
    hamo pipa Komšija
    Vidi se mladost :D
    Sent from my Redmi Note 4 using Tapatalk
    Neo Bahamut Zero likes this.
Share This Page
