nakon sto sam prilikom instalacije win 7 podijelio hd od 500mb na 2 partijice od 100 i 400 nakon istalacije je vidljiva samo ova od 100, ali ostatak od 400mb je nevidljiv tj. nema druge partijice. da ne bih ponovo radio instalaciju...zna li neko o cemu se radi?
@blaf napravio si 400gb? unallocated prostora,sto znaci da samo trebas taj prostor napraviti u jednu particiju.To mozes uraditi sa svakim programom za pravljenje particija ili control panel/administrative tools/computer management/storage/disk management
Ova od 400 ti je vjerovatno raw. Trebaš je napraviti pa formatirati. Najlakše ti je preko disk managementa. Samo nemoj zuriti da ne bi sta zeznuo. Here's How: Click on the Start button and then choose Control Panel. Click on the System and Security link. Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link so just click on the Administrative Tools icon and skip to Step 4. In the System and Security window, click on the Administrative Tools heading located near the bottom of the window. In the Administrative Tools window, double-click on the Computer Management icon. When Computer Management opens, click on Disk Management on the left side of the window, located under Storage. After a brief loading period, Disk Management should now appear on the right side of the Computer Management window. Note: If you don't see Disk Management listed, you may need to click on the |> icon to the left of the Storage icon. You can now partition a hard drive, format a hard drive, change a drive's letter, or do whatever else you need to do in Windows 7's Disk Management tool. EDIT: prestigo me Irhad
Desni klik na My computer ikonu, kliknes na manage, i onda kliknes na storage managment. Ako vidis tu particiju od 400GB a da nema slova kao na primjer D ili E onda kliknes na nju desnim klikom i onda kliknes na "change letters or paths". Otvori se mali prozor i kliknes na opciju Add, dodas slovo po zelji (samo da nije C) i save. Particija ce se pojaviti nakon toga, isti postupak je i ako zelis da sakrijes particiju, samo izbrises zadano slovo za nju.
