Imao sam IIS instaliran (za asp stranice, localhost). I pokusao neki dan otvoriti asp stranice, i nece. Pokusavao sam sve i svasta, ali nije upalilo. Reinstall IIS, registrovanje odredjenih fajlova, davanje dozvole svim korisnicima da imaju potpunu kontrolu u C:\Inetpub\wwwroot\... Cesto imam problem sa IIS, i vise me zivcira previse. Sada bi, kao uvijek morao formatirati disk da bi mi IIS radio normalno. Evo greske koja se otvori kada pokusam ocitati sve podatke iz baze test.mdb: Error Type: Microsoft OLE DB Provider for ODBC Drivers (0x80040E37) [Microsoft][ODBC Microsoft Access Driver] The Microsoft Jet database engine could not find the object 'ime'. Make sure the object exists and that you spell its name and the path name correctly. /Dejan Dujmovic/test.asp, line 13 U dreamweaveru, vidim da se prime podaci ok, ali nece nikako da radi normalno kada pokrenem u browserima. Svima prikazuje istu gresku. Evo koda stranice te: <%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%> <!--#include file="Connections/testiranje.asp" --> <% Dim Recordset1 Dim Recordset1_numRows Set Recordset1 = Server.CreateObject("ADODB.Recordset") Recordset1.ActiveConnection = MM_testiranje_STRING Recordset1.Source = "SELECT * FROM imena ORDER BY ime ASC" Recordset1.CursorType = 0 Recordset1.CursorLocation = 2 Recordset1.LockType = 1 Recordset1.Open() Recordset1_numRows = 0 %> <% Dim Repeat1__numRows Dim Repeat1__index Repeat1__numRows = -1 Repeat1__index = 0 Recordset1_numRows = Recordset1_numRows + Repeat1__numRows %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /> <title>citanje</title> </head> <body> <% While ((Repeat1__numRows <> 0) AND (NOT Recordset1.EOF)) %> <%=(Recordset1.Fields.Item("ime").Value)%> <% Repeat1__index=Repeat1__index+1 Repeat1__numRows=Repeat1__numRows-1 Recordset1.MoveNext() Wend %> </body> </html> <% Recordset1.Close() Set Recordset1 = Nothing %> Pomazite sada, ja poludi. Maturski trebam raditi a necu da formatiram disk sada. To je onda laka predaja. 8)
