Prodajem Sapphire Radeon 3450 HD - 512 mb - kupljena prosle godine u aprilu (ako se ne varam ) - placena 140 KM . 60 KM Kontakt : 062-156-303 Saljem City Ex-om ili postom pouzecem . Specifikacije : The SAPPHIRE HD 3450 AGP brings the features of the highly acclaimed HD 3000 series to the users of older PC systems with the AGP graphics bus. In addition to dramatically increased graphics performance, this means support for all the latest generation of games with DirectX 10.1 and the ability to smoothly play HD and Blu-Ray DVD’s with the built-in hardware UVD decoder. It also allows users to accelerate tasks such as video transcoding (converting video formats to play on portable devices) and other new applications supporting ATI Stream technology. Microsoft® DirectX® 10.1 support 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering AGP 8X/4X Support Dynamic geometry acceleration Game physics processing capability Unified Video Decoder for Blu-ray™and HD Video Accelerated Video Transcoding(AVT) DVD Upscaling Dynamic Contrast 64-bit DDR2 memory interface Microsoft® DirectX® 10.1 support Shader Model 4.1 32-bit floating point texture filtering Indexed cube map arrays Independent blend modes per render target Pixel coverage sample masking Read/write multi-sample surfaces with shaders Gather4 texture fetching Unified Superscalar Shader Architecture 40 stream processing units Dynamic load balancing and resource allocation for vertex, geometry, and pixel shaders Common instruction set and texture unit access supported for all types of shaders Dedicated branch execution units and texture address processors 128-bit floating point precision for all operations Command processor for reduced CPU overhead Shader instruction and constant caches Up to 16 texture fetches per clock cycle Up to 128 textures per pixel Fully associative vertex/texture cache design DXTC and 3Dc+ texture compression High resolution texture support (up to 8192 x 8192) Fully associative texture & Z/stencil cache designs Early Z test, Re-Z, Z Range optimization, and Fast Z Clear Lossless Z & stencil compression 8 render targets (MRTs) with anti-aliasing support Physics processing support Dynamic Geometry Acceleration Programmable tessellation unit Accelerated geometry shader path for geometry amplification Memory read/write cache for improved stream output performance Anti-aliasing features Multi sample anti aliasing (2 or 4 samples per pixel) Custom Filter Anti-Aliasing (CFAA) for improved quality Adaptive super-sampling and multi-sampling Temporal anti-aliasing Gamma correct Super AA (ATI CrossFire™ configurations only) All anti-aliasing features compatible with HDR rendering Texture filtering features 2x/4x/8x/16x high quality adaptive anisotropic filtering modes (up to 128 taps per pixel) 128-bit floating point HDR texture filtering Bicubic filtering sRGB filtering (gamma/degamma) Percentage Closer Filtering (PCF) Depth & stencil texture (DST) format support Shared exponent HDR (RGBE 9:9:9:5) texture format support OpenGL 2.0 support ATI Avivo™ HD Video and Display Platform Dedicated unified video decoder (UVD) for H.264/AVC and VC-1 video formats High definition (HD) playback of both Blu-ray and HD DVD formats Hardware MPEG-1, MPEG-2, and DivX video decode acceleration Motion compensation and IDCT ATI Avivo Video Post Processor Color space conversion Chroma subsampling format conversion Horizontal and vertical scaling Gamma correction Advanced vector adaptive per-pixel de-interlacing De-blocking and noise reduction filtering Detail enhancement Inverse telecine (2:2 and 3:2 pull-down correction) Bad edit correction Two independent display controllers Drive two displays simultaneously with independent resolutions, refresh rates, color controls and video overlays for each display Full 30-bit display processing Programmable piecewise linear gamma correction, color correction, and color space conversion Spatial/temporal dithering provides 30-bit color quality on 24-bit and 18-bit displays High quality pre- and post-scaling engines, with underscan support for all display outputs Content-adaptive de-flicker filtering for interlaced displays Fast, glitch-free mode switching Hardware cursor Two integrated DVI display outputs Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1 Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1 Each includes HDCP encoder with on-chip key storage for maximum resolution playback of protected content2 Two integrated DisplayPort™ outputs Supports 24- and 30-bit displays at all resolutions up to 2560x16001 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane Two integrated 400 MHz 30-bit RAMDACs Each supports analog displays connected by VGA at all resolutions up to 2048x15361 HDMI output support Supports all display resolutions up to 1920x10801 Integrated HD audio controller with up to 2 channel 48 kHz stereo or multichannel(5.1) AC3 enabling a plug-and-play cable-less audio solution Integrated AMD Xilleon™ HDTV encoder Provides high quality analog TV output (component/S-video/composite) Supports SDTV and HDTV resolutions Underscan and overscan compensation MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding Seamless integration of pixel shaders with video in real time VGA mode support on all display outputs ATI CrossFireX™ Multi-GPU Technology Scale up rendering performance and image quality with two GPUs Integrated compositing engine Some custom resolutions require user configuration 11. Playing HDCP content requires additional HDCP ready components, including but not limited to an HDCP ready monitor, Blu-ray or HD DVD disc drive, multimedia application and computer operating system 12. Dual channel interconnect is not required for ATI CrossFire, and may not be included in all product configurations SAPPHIRE Radeon HD3450 AGP System Requirements AGP based PC is required with one 4X/8X AGP slot available on the motherboard 300 Watt or greater power supply is recommended with one 6 pin power connector Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products 1GB of system memory recommended Installation software requires CD-ROM drive DVD playback requires DVD drive Blu-ray™ playback requires Blu-ray drive and full 1080p display requires a 1080p-capable monitor Preuzeto sa - http://www1.sapphiretech.com/us/product ... p?gpid=314
Refresh ! 65 km + moja postarina . Graficka je skoro nova , originalna kutija i sve sto dodje uz nju .
